  1. Hi
    Just received my ADVC-100 and connected it up to my VCR (PAL) but I'm not getting anything. Unfortunately I don't have any outputs on my VCR other than SCART. I've got a neat little connector to convert my scart socket to RCA but no signal. I've checked the ADVC using a DVD player and it works fine. Tried changing the PAL/NTSC switch. Can't see what else it could be. Any suggestions?
    I'm connecting to a Mac through firewire and I'm using iMovie.
    Cheers.
  2. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    My scart/composite adapter has a output/input switch, does yours?
    (clutching at straws, I know), but I've just bought the ADVC too and use the same procedure as you.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  3. Don't think it does. Maybe it only works for input. I've only ever used it to record from DV to VHS before.
  4. Lost Will Hay's Avatar
    Oct 2002
    One avenue to explore.
    I'm betting it's imput only.
    Good luck
    Will
  5. Member rhegedus's Avatar
    on the jazz
    Plug the leads into your TV first - if you get a picture, then you can output.
    Regards,
    Rob
