I've got a question regarding my new DVD Writer and VCD's.
I've got many VCD's (MPEG 1) on my PC (e.g. Friends episodes). I rip the tv-series directly into the VCD Format (working fine with my hardware). Usually I use Nero 5.5 to create a VCD with 3 episodes on it (inc. menu and picture).
Now i would like to have many of those VCD's on one DVD.
Instead of having 3 episodes it could be around 20 on one DVD. Is there a way to do it? Nero won't let me write VCD on a DVD (as far as I've seen). Do I need some other tools to do that?
Thanks for your help.
HH
AFAIK vcd mpeg1 is a valid dvd resolution so the raw mpeg files could be imported into any authoring DvD package.
Except for NTSCfilm framerate VCD's. These are not valid for DVD (must be 29.976fps or 23.976fps with 3:2 pulldown, mpeg-1 does not support pulldown).Originally Posted by RabidDog
Also, the audio needs to be upsampled to 48khz to be DVD compliant. -
http://www.lordsmurf.com/convert/vcdtodvd/vcdtodvd.htm i follow this guide but it came up with some error which it cant be ignored.....any ideas?
Just follow the guide at https://www.videohelp.com/vcddvdr.htm and you'll be fine. Here's an outline of the process (very simple).
1) Use VCDGear or VCD Easy (tool) to generate a MPEG1 file from your VCD DAT file. NO NOT just drag/drop DAT file to HD and re-name *.mpg While this often works a DAT file and a MPEG1 file are not quite the same thing.
2) Use TMPGenc to demux the MPEG1 file into sepeare m1v (video) and mp2 (audio) streams.
3) D/load SSRC and tooLame. Use TMPGenc as a GUI for tooLame and SSRC to re-sample the audio from 44.1khz to 48khz. Make sure you choose to encode ONLY THE AUDIO with TMPGenc, the m1v video file is fine
4) Author DVD using m1v and 'resampled 48khz mp2' file
5) Burn
I've dumped quite a few VCDs onto a single DVDR this way with out any major problems. If you want to be really safe you can convert the 44.1khz mp2 file to a 48khz ac3 file:
http://www.doom9.org/audio-guides.htm
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
