I currently use TMPGEnc DVD Author get my various movie files authored. Right now, I am trying to maneuver around one of its limitations. Menu highlights cover the entire image and cannot be changed within the program. I thought there should be a way to edit the subpicture to create a frame around the menu buttons instead of covering them.
I ran across a post stating Subrip would be able to extract the menu overlay (subpicture). I gave it a try and it worked! Now, my plan is to edit the subpicture (a black bitmap with white "holes" over the menu navigation elements) in Paint Shop Pro and author it back into the menu.
My question is: since DVD Author can not import the subpicture, can anyone recommend a program that will replace the overlay in the menu? I'm looking into MenuEdit to see if it offers what I am seeking.
Any pointers would be greatly appreciated. Thanks.
Results 1 to 1 of 1
Modifying NTSC MPEG-2 with Restream
By Anonymous344 in forum Video ConversionReplies: 18Last Post: 25th Mar 2010, 16:11 -
One subpicture overlay across menu cells? - DVDLab Pro
By nostrum in forum Authoring (DVD)Replies: 0Last Post: 8th Feb 2010, 10:36 -
Multiple subpicture streams in menu for different color schemes?
By Alex_ander in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2008, 02:53 -
DVD Lab "the subpicture of menu 1 is created from copy of external fil
By BeachNut in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 08:05 -
Modifying a home video
By chrishallowell in forum Newbie / General discussionsReplies: 7Last Post: 28th Aug 2007, 10:39
