I am using a Liteon LDW-401s and Bulkpaq 4x DVD+R. my problem is, when i goto burn the disk, either at the start of the process or the end, the burn process fails: Power calibration error, were it fails..but also if its not that error its this one...
10:32:37 AM #25 CDR -1176 File ThreadedTransferInterface.cpp, Line 1594
Session fixation error
10:32:37 AM #26 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1594
Could not perform end of Disc-at-once
10:32:45 AM #27 Phase 127 File dlgbrnst.cpp, Line 1818
Generating DVD high compatibility borders
10:33:05 AM #28 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
10:33:05 AM #29 Phase 129 File dlgbrnst.cpp, Line 1818
Generating DVD borders completed successfully
10:33:05 AM #30 Text 0 File dlgbrnst.cpp, Line 1678
10:33:05 AM #31 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 2.4x (3,312 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 7:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.60a, size=17232 bytes, created 8/27/2003 2:02:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 12:27:50 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Ive used this media before and it worked fine? not one coaster, but now its 2in3 are failing...I upgraded the firmware to es0g, but still the same. so i have a DVD+RW and i tried it on that, it worked fine...So is this the media? if so why did it work ok the first time i got it (but from a different supplier) THX...sasarchiver
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights -
I ran into this with my liteon 401s. It was with the same version of the firmare and nero 6.019 when I upgraded nero the problem went away. Also the disk was not burned when I had the power calibration error so I could burn sucessfully when I set the speed at 2.4 before the upgrade. This was with Fuji media that was working at 4x before the firmware upgrade and at 2.4x after the upgrade. When I upgraded nero I could burn at 4x again. This problem happened with any program that uses nero asapi before the upgrade. In my case the problem was only at the start.
so upgrading ur nero fixed this problem for you then? i dont understand, one day its fine, next thing, it spits out the disks. nothing has changed, that im aware of? Damn strange thing...Sasarchiver (more help/tips appreciated)
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
