Folks,
In my continuing support for all formats of DVD. I have added a much requested bitsetting compatibility for BENQ DW400A and DW800A drives.
This version is as yet unreleased and I need some testers. Spaces are limited to act now.
The bitsetting for BENQ is very comprehensive and contains both +R / +RW default modes, and Direct altering of +RW disks immediately.
cheers
NicW
www.dvdinfopro.com
www.dvdrrw.org
Results 1 to 9 of 9
nicw
I could test the NEC ND-1300 bitsetter...but I haven't any dvd player too check that it works fine though....so it isn't maybe that useful.
i have a benq dw400a in a h.p. a367c ,and i am running 123copydvd software and it burns dvd+r and dvd/rw just fine but i got a deal off ebay for 500 hundred dvd-r blanks which was suppose to be +r so i am stuck with them , can anyone tell me how i can make my burner burn dvd-r blanks???
i have a dw400a with 123 copydvd software , it will burn plus /r and rw good , i bought 500 hundred dvd-r off a ebay deal by mistake , can anyone tell me how i can get my burner to work with a dvd -r ?? -
DVD-Rs will NOT work with your burner (see https://www.videohelp.com/dvdwriters.php?DVDname=benq+dw400a&Submit=Search&cdrs=&cdrws=...&Search=Search)Originally Posted by mikenleeds
BenQ has put out firmware updates to allow some of its 8x +R drives to burn -R discs, but I'm not sure if they'd done anything for the DW400. My only other suggestion would be drawing a vertical line through the - on the disc, but something tells me that won't work either.
Nothing can stop me now, 'cause I don't care anymore. -
thanks guy but drawing the small line on the blanks did nt help , good idea though ,,, if anyone knows to to make my burner write on dvd-r please speak up
Has anyone tried Benq's own bitsetting utility called "book-type management"? I've used it with both an 800a and 822a drive with no problems.
I bought a BenQ 16 DVD writer from futureshop about 3 weeks ago I couldn't get it to write or read certain media, the same media that works great on my LG's, I took it back no help from tech suport or their web site.
That Benq will not work with most -R media. A friend bought one with his $5K system and found out the hard way that it likes +R media only. Benq/Philips should be shot over that drive...
Heat added
By alintatoc in forum ComputerReplies: 25Last Post: 27th Aug 2011, 10:06 -
Bitsetting compatibility
By davidprosser in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2011, 14:39 -
Does a Samsung TS-H653N support bitsetting?
By raryke in forum DVD & Blu-ray WritersReplies: 4Last Post: 26th May 2009, 11:54 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 14:58 -
Any Pioneer burners do bitsetting?
By kenmo in forum DVD & Blu-ray WritersReplies: 62Last Post: 7th Jul 2008, 23:33
