Hello
I have been reading loads on the possibility of upgrading the firmware
on my Sony DWU14A dvd writer (OEM) to the official Sony DRU510A
version (currently 1.0d)
My reason for doing this is that I have found that some movies start
jumping on the DVD -r that I am currently burning to (Dabs home brand
unfortunately). Does anyone have any horror stories about doing this
before I go ahead and do it? Apparently the firmware is the only
difference between the official and the OEM version. Do I gain enough from completing this to make the upgrade worthwhile? Finally, does anyone wlse have this jumping issue towards the end of movies. Your views will be appreciated.
Dell 2.8Ghz P4
Windows XP Home
Cheers
Andy
I think that your problems with "jumps" are due to you are filling so much the media. To avoid this problem I suggest you donīt full them so much (For example, if you are using Princo or Sky or Millenium ,I will writte on them about 4,2Gb , no more ).The other solution is that you buy good disk like Verbatim, TDK, Sony. I know that they are more expensive than the others, but with theirs you wonīt have problems.
Bye -
I bought this drive (DWU14A) a few months ago. I flashed with a hacked version of the current firmware at the time (1.0d i think). It's been working like a charm. However, in hindsight - if you are considering updating your firmware - I would definitely do the update (from OEM to full DRU510A). Otherwise, you reduce yourself to having to hunt down a hacked version of the latest firmware everytime you want to upgrade. Cheers!
I recently ran sonys updater for my dru-510A burner.
I dont know if I updated my firmware, cause when I rebooted the program was still running and after I closed it windows xp was running properly. Now when I check the version of firmware with nerotool its 1.0d.
Want to Upgrade my Sony Handycam
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 9th Jun 2011, 11:34 -
Sony Wants to upgrade my Ps3 or refuses to play disks.
By cal_tony in forum DVD & Blu-ray PlayersReplies: 22Last Post: 20th Apr 2011, 22:17 -
Sony BDP-S370: Firmware upgrade to 567 and region free hack
By Nosh3 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jan 2011, 08:57 -
FIRMWARE for SONY DVD
By yangp in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Dec 2008, 15:44 -
Sony (Pioneer) hard drive upgrade problems.
By prime in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Dec 2007, 13:56
