I have done quite a few dvd backups with no problems, but when I do 'fierce creatures' when I come to play the dvdr on my dvd player I get the message "the disc is not formatted to play in this region" never had this before, the original plays okay. All I have done is use dvd decrypter and burnt it (less that 4gb) using recordnow and copytodvd (neither worked). Have I changed the settings somehow on dvd decrypter? I have posted this problem on other forums and nobody has yet worked out what the problem is.
Thanking you
Scorer
what region is your 'fierce creatures'???
once you know what region it is, make sure thats the region dvd decrypter is set to. -
Its region 2 mate, like all the others I have done have been, so why should this be different. Doesn't dvd decrypter make it multi region?
Yeah dvd decrypter makes it multi region but it has to know which region to unlock it from (in your case region 2)
load up dvd decrpter
select tools
settings
then make sure the RCE Pritection region is set to region 2
after this it should work Give it a try
what wrong with this code?
By emogal in forum ProgrammingReplies: 3Last Post: 11th Jan 2009, 04:12 -
What's wrong with my Canon HV-30?
By stompinne in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2008, 09:45 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
