  1. Mr Anderson
    Guest
    I have not been able to get this program to work for MPEG-1 or Mpeg-2 encodes using a variety of input files. I recently posted about being unable to re-encode an mpeg-4 file to mpeg-1 or -2; now a video-ts file will not encode. All of this use to work under 0.0.6g. I installed 0.0.9a, and all of the binaries as instructed : and got no error messages. Now problems. Here is a post of my terminal window:
    Last login: Tue Dec 2 21:43:56 on ttyp1
    pbpaste | sh
    Welcome to Darwin!
    [mr anderson's Computer:~] randolph% pbpaste | sh
    Encoding started on Tue Dec 2 21:43:57 CST 2003
    -f 5 -b 2500 -q 6 -B 260 -V 230 -a 2
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    **ERROR: [mpeg2enc] Unable to open: Proj/Silly_Songs/SillySVCD.mpv:
    No such file or directory
    **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
    Using GNU internationalization
    Original domain: messages
    Original dirname: /usr/local/share/locale
    Current domain: mplayer
    Current dirname: /usr/local/share/locale
    MPlayer dev-CVS-030316-14:10-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
    AltiVec not found
    Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory
    Reading config file /Users/randolph/.mplayer/config
    Reading /Users/randolph/.mplayer/codecs.conf: can't open '/Users/randolph/.mplayer/codecs.conf': No such file or directory
    Reading /usr/local/etc/mplayer/codecs.conf: can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
    Using built-in default codecs.conf
    CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/Users/randolph/Desktop/Video' 'Proj/Silly_Songs/TITLE01-ANGLE1.VOB' '-aid' '128'
    get_path('font/font.desc') -> '/Users/randolph/.mplayer/font/font.desc'
    font: can't open file: /Users/randolph/.mplayer/font/font.desc
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    Using Unoptimized OnScreenDisplay
    Using usleep() timing
    get_path('input.conf') -> '/Users/randolph/.mplayer/input.conf'
    Can't open input config file /Users/randolph/.mplayer/input.conf : No such file or directory
    Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
    Falling back on default (hardcoded) input config
    get_path('Video.conf') -> '/Users/randolph/.mplayer/Video.conf'
    Playing /Users/randolph/Desktop/Video
    Not an URL!
    File not found: '/Users/randolph/Desktop/Video'
    get_path('TITLE01-ANGLE1.VOB.conf') -> '/Users/randolph/.mplayer/TITLE01-ANGLE1.VOB.conf'
    Playing Proj/Silly_Songs/TITLE01-ANGLE1.VOB
    Not an URL!
    File not found: 'Proj/Silly_Songs/TITLE01-ANGLE1.VOB'
    Exiting... (End of file)
    Here is the "open" info as shown in the ffmpegX gui:
    /Users/randolph/Desktop/Video Proj/Silly_Songs/TITLE01-ANGLE1.VOB
    I cannot get this version to work. Can anybody help? Please.
  2. Guest
    This is *not* the file info, as repeated already many times by other user.
    The file info is *above* that !
    In this particular case I would suggest that you remove the space out of your folder name "Video Proj"
