Thanks.
Results 1 to 29 of 29
I started out with a good search engine!
then a dvd burner
and nero6 or recordnow max
thats it!If at first you don't succeed; call it version 1.0 -
You'll also need some sort of modification on your game console if you plan on playing those backups.
is this a bad question or doesnt anybody here know how to do this??
Are you serious??[/quote]If at first you don't succeed; call it version 1.0 -
Copy disc?? That's all?? Do I need to use a blank dvd or blank cdr??
Copy as audio or data?? Sorry, I'm a newbie. Thanks . Can I use the Roxio Easy CD Creator that came with my Dell? -
Originally Posted by canyouhelpme???
DVD You do have a dvd writer dont you?? And I copy mine as a 1:1 copy
ut-oh...ps2daddy is here...Im no longer of any help!!
PS2daddy--> how can you tell if it's a CD or DVD game??
FYI: I updated my computer specs too. -
One more thing, I use DVD Decrypter--> DVD2One-->Copy2DVD to make back ups of movies....would I use the same for back ups of PS2 games??
Recordnow max
Nero
Easy CD/DVD Creator
Alcohol 120%
Dont forget you will need to get a hold of a mochip or Boot CD/DVD also -
Also look for ps2 tutorial using the search function on this board and you will find some good stuff -
why do you need a mod chip if you are doing a 1:1 copy of the dvd.
well if i remember correctly and it is the same from the PS1 then there is a certain encryption or something along with that black disk they give you. The mod chip bypasses the encryption and allows the burned disk to be played.
I remember doing the swap trick with the first ps1. You tricked the machine into thinking it was an original black disk in the machine.
HatzLoves the funeral of hearts..... -
Use dvdshrink and recordnow max for movies
Also look for ps2 tutorial using the search function on this board and you will find some good stuff[/quote]
Why do you suggest dvdshrink and recordnow max for movies? I'm backing up my movies fine with DVD Decrypter--> DVD2One-->Copy2DVD. -
so you're saying I can use Roxio Easy CD Creator 5 and that will work?? Just burn it as a CD Copier?? No decrypting is necessary??
What if it's a DVD game, would i insert a dvd and use CD Copier or would that not work??
I would still need to get something like a case though right
--> http://www.ps2case.com/ -
5 is just Easy CD creator
For a dvd game you need a dvd burning program
some dvd burning program will also burn cds but none of the cd programs will burn dvds.
Yes you will need a boot disk and a way to fool the ps2 to think tht it has never been opened to play a backup like a flip top ,slide card, or no solder mod. (heck you can just buy a boot disk and never put your top back on if you like.)
I recommend a chip though for ps2 games you just stick them in and they play as normal without switching 1-3 disks to play certain games as you would with a flip top or boot disks.
I am an installer if you need one -
ps2daddy..... you are an installer? I need to get with you then and maybe get you to install one for me. I see all your posts on this and I would like to have you do that for me if possible. Depends on your advice, I know how to solder and no doubt I could do it with advice, but I just need to know your input. Thanks.
canyouhelpme???....what part of Illinois are ya from?If at first you don't succeed; call it version 1.0 -
If you make a movie on + r and it works than you know that a game will work
Also there are sites like
cdrom-guide.com
ps2newz.net
ps2ownz.com
They have tons of ps2 info -
1- DVD Decrypter
2- RecordNow MaxWant my help? Ask here! (not via PM!)
Basic AVCHD video Editing Tools
By glenpinn in forum EditingReplies: 27Last Post: 18th Jun 2009, 09:14 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 11:12 -
HOW TO BURN Ps2 games MDF/MDS on MAC OSX
By kimkimkimmykim in forum MacReplies: 7Last Post: 2nd Nov 2007, 02:52 -
Copy PS2 games
By hummer in forum ComputerReplies: 1Last Post: 25th May 2007, 11:58
