Hi
I have been practising copying DVDs with several tools but I have this doubt as to what final format have my copies come out as.
For the first I used DvdFAv to copy the main movie and burned with Nero
The other method used anydvd and Elby's Clone DVD again to copy the main movie and menus
How can I identify and know in what type of final format and what conventinal DVD player will they play on?
Thank you
PS and the media used is Maxell DVD-R
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID MXLRG01
Format Type UDF 1.02
don't know if i fully understand your question but the final format is the same as the format you used as the source...vob files that is a DVD. look at the files in Explorer.
Ok I'll try to express myself better
Will these DVD-r be playable in any standard DVD player and or PS2 or Xbox consoles?
I'd like to share some of these movies with my friends and I don't know if this is possible since some palyers will restrict to some formats or reject non original copies.
thank you -
if you check this site's dvd player list you can find out which dvd players will play dvd-r's.
https://www.videohelp.com/dvdplayers
the playstation 2 and xbox should be able to play dvd-r's. -
... however they can be very fussy about which brands they will play.
All media is not created equal ! -
Thanks for the link to players but yes that is right no all players will play recorded DVDs few of them are picky
I have been offfered a Pioneer that handles most formats except DVD+R but I guess perhaps I should wait for LiTeOn player -
It also depends on the burning software. You could have a DVD compliant VIDEO_TS folder but if your burning software doesn't burn the data correctly (like using UDF 1.5 instead of 1.02 or something to that effect), your DVD player may reject the disc.
Very Basic--> What format to work with Final Cut with my HD cam.
By Mcjuicypants in forum EditingReplies: 0Last Post: 5th Mar 2011, 20:55 -
Help with correct file format for video! Final Cut Studio
By matt_shaban in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2009, 14:05 -
Exporting from Final Cut Express to P2 native (MXF?) format?
By Cyrax9 in forum MacReplies: 2Last Post: 1st Jun 2009, 14:55 -
Managed Copy to be absent from final AACS specification
By Vrex in forum Latest Video NewsReplies: 5Last Post: 15th May 2008, 23:24 -
How To Copy DvD To File Format
By lljav77 in forum Newbie / General discussionsReplies: 9Last Post: 18th Jul 2007, 20:04
