I am trying to start the SVCD2DVD program but all I get is "Validation Failure due to XMLLoad"
What does that mean?
I saw a previous post elsewhere and it was suggested to uninstall and re-install the program - which I did and it still gives the same errorr.
And I installed the lastest Dot Net from the link provided on the site.
I am able to open up the other program svcd2dvdmpg (free) but I want to run the demo of this one and see if it will suite my needs..
Results 1 to 10 of 10
eliteGuest
Interesting.
You want to run the demo but are getting this error? and you want to try the demo before you get the FULL version?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
eliteGuest
yes - that is right - i think it is a demo - coz it says on your page that demo will work but will have intro of few mins worth at the beginning and will expre on a certain date.... corect.
Well if you download the demo from:
http://www.svcd2dvdmpg.com/SVCD2DVDMPG/Software/svcd2dvd_demo.aspx
you'll be alright. Why? because the error you describe is associated with the version available to registered users. So either you are a registered users who has forgotton and is now using the demo to see if you should re-register...or you have obtained a copy of the registered version improperly.
Which is it?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
eliteGuest
I got mine form easynews - since it did not have any nfo or crack or serial or anything I presumed it was a the normal demo version that was on your site - I will try getting the download from the link and see how this works.
Originally Posted by elite
Why go to Easynews to get a copy, If you want to try stuff go to the site where the software comes from....
Or you were looking to save yourself £10 by getting a hacked version....Not bothered by small problems...
Spend a night alone with a mosquito -
Hey. I'm having the same problem that dude had but I actually paid for the enhanced version. What am I doing wrong?
I figured it out. When I extracted the reg file it was named ZippedFile. Once I changed the name to reg.xml and ran the program again it worked fine.
Actually I figured it out after reading the FAQ. I'm a dumbass. -
No thermalundy it is my mistake. I change my zip algorithm and screwed up the name of the file. You're right it should be reg.xml not ZippedFile.
Therefore anyone else who has a file called ZippedFile in the attachment zip should extract the file rename it to reg.xml & then move it to the SVCD2DVD folder.
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 16:34 -
Due to converting from flv to mp3 ffmpeg runs out with error
By Maxroy in forum Video ConversionReplies: 3Last Post: 7th Oct 2010, 15:23 -
Error first sec due to wrong streams?
By simchippy in forum ffmpegX general discussionReplies: 1Last Post: 4th Aug 2008, 12:41 -
I/O Error! Program Memory Area Update Failure
By Bruxo in forum DVD & Blu-ray WritersReplies: 9Last Post: 24th Dec 2007, 07:51 -
ffmpeg failure when using svcd2dvd
By cathalcelia in forum SVCD2DVD & VOB2MPGReplies: 26Last Post: 11th Oct 2007, 20:10
