Tmpegenc can not import DV type I data.
My system configration:
P4 1.4G, Windows 2000, Ulead MediaStudio Pro 6, TMPGENC 12a, DV camcord
My process is:
1. Capture DV, using MSP6 video capture program, OK.
2. Import the data to MSP6, edit, OK.
3. Export to .avi file, DV type I format, OK. Can play back using media layer
4. If the file is less than 1 minute, import to TMPGENC, OK
If the file is little bit larger, can not import to TMPGENC.
when import to TMPGENC, the harddisk run run run for some minutes, then system halt.
If in step 3 above, I save as DV type II .avi file.
Then everything is OK, can be import to TMPGENC, Can encode to mpeg2, can
write to svcd, can play back.
Why, can not DV type I? I save as DV type II, need lots of time. :
Yes it can. You have to have the priority of the Directshow Multimedia File reader higher...(environmental settings>VFAPI plug-in tab)
That's how i can get my files to work.
TMPGenc Authoring Works 4: Import custom Buttons
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 31st Aug 2016, 22:14 -
Software to import, analyze and export mp4 file collection data is needed
By spycam in forum Newbie / General discussionsReplies: 2Last Post: 21st Dec 2011, 18:24 -
Can I import 4PM or MKV with 2 Audio Streams into TMPGEnc Authoring W 4?
By JackyWang in forum Authoring (DVD)Replies: 2Last Post: 27th May 2011, 09:56 -
DVD menu software to import into TMPGEnc Authoring Works 4
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 28th May 2010, 14:34 -
TMPGEnc DVD Author 3 can't import AVI video, only audio?
By XyBeRz in forum Authoring (DVD)Replies: 7Last Post: 31st Jan 2009, 10:54
