I wanted to know if anyone does this as suggested by:
https://www.videohelp.com/dvanalog
If so, what digital camcorder is the best for doing this ? Im trying to connect my Sony Camcorder that only handles 8mm cassettes to a digital camcorder with A/V IN so I can capture it then run it through to my computer.
Any suggestions appreciated - thanks!
If you have a firewire input on your PC AND
your camera will play analog tapes and output DV do that.
If your camera only has analog out you need either another camera
that has passthrough OR an analog capture card. Don't even bother with
USB1 -
Yeah i wanted to get another camera that has the passthrough capability both analogue and digital. I just wanted to know which model/brand would be good for this use.
thanks! -
The Sony TRV350 can play digital and analog 8mm tapes and has a analog to digital pass through. There was some discussion about this half way through this posted topic: https://www.videohelp.com/forum/viewtopic.php?t=188585
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 03:15 -
Converting old 8mm tapes to digital..help!
By MrMister007 in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 23:59 -
8mm tapes PAL with NTSC camcorder????
By igorv in forum Capturing and VCRReplies: 5Last Post: 11th Oct 2010, 14:17 -
I have about 60 Hi8 and regular 8mm camcorder tapes that I can't get toplay
By Chris McDowell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Jun 2010, 19:12 -
Help with old 8mm camcorder tapes
By AmandaBMidlands in forum Portable VideoReplies: 2Last Post: 11th Nov 2008, 09:43
