My audio is slightly behind my video. I cannot find (I have looked. I promise) where to correct the audio to video timing. Where is it? Thank you for any assistance.
Under settings, on the advanced tab, select the source range option (tick box) and then double clic on the words 'source range'. A new dialo will open with an 'Audio Gap Correct' setting at the bottom. Enter the adjustment value in Milliseconds.
Hope this Helps
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 13:03 -
Adjust audio that is too high
By roglopes in forum AudioReplies: 11Last Post: 3rd Apr 2011, 08:26 -
Is there such a tool that would go through my AVI and adjust the audio lvl?
By Chrushev in forum RestorationReplies: 3Last Post: 22nd Oct 2009, 16:36 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 14:07 -
Adjust audio volume with FairUse Wizard or later
By 2dpikke in forum DVD RippingReplies: 5Last Post: 5th Jul 2007, 23:40
