I have two video clips that are in an AVI format that Premiere 6.5 and Ulead 6 do not recognize. Ulead actually tells me that it can not find "vidsvid" I tried using Main Concept MPEG encoder to change the format but it doesn't recognize the AVI format either. Anyone got any ideas? I do not have an orignal source to try and recapture the video. This is all I have to work with. I can play the files in the latest DivX player only.
Get the 4cc changer app over in the tools section. Change the 'xvid' header to 'divx' for both and it should work fine.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Im a newbie at this... I need to know if you are refering to doing this in Premeire and a step by step process if you don't mind.Originally Posted by Gazorgan
im asuming you mean the "tools" section of the website now that I look at it. I have searched for "4cc" and nothing shows up. What do i need to look for?
I don't remember the name, and the searchpage doesn't do keywords (go figure).
It's here: http://www.inmatrix.com/files/avic_download.shtml
It has nothing to do with Premiere (which is picky about source files). Run it, open the AVI, make both lines say divx and hit the update button. Then try Premiere. Remember MPEG4 is MPEG4, and generally any decoder will work, assuming it knows to decode in the first place and isn't confused.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Change video to another format?
By Venessa@123 in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2011, 03:10 -
Unrecognized Format
By sergiozambrano in forum Authoring (DVD)Replies: 1Last Post: 9th May 2010, 22:38 -
Best format and method to upconvert and change ratio of video project?
By Joseph C. Krause in forum MacReplies: 4Last Post: 3rd May 2010, 05:35 -
VIDEO-TS.......how do i change format from disc to my video files
By COT51E in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2008, 12:32 -
Why is source format Unrecognized?
By iOBEYchris in forum ffmpegX general discussionReplies: 4Last Post: 2nd Feb 2008, 03:22
vid" I tried using
