I have a hard time deciding what authoring program to chose. I have tried Ulead MF2, and I liked it, but I could not make it keep audio and video in sync and now my evaluation period is up.
TMPGEnc DVD author seems to be almost as easy and a bit more powerfull.
But this one also gives me a little problem:
When played in my stand alone (Pioneer DV-757Ai), the only way to get to the meny is to eject and reinsert the disk. Pressing the menu button does not work.
Is there anybody that can tell me what I am doing wrong??
on the tab there is options what you want your disk to do,select play main menu then play tracks,,,,,,,,when you insert dvd it goes to the main menu...
Thanks for reply, but that was not the problem.
When I insert the disk, I get the menu and can select a track.
What I was trying to ask, is how I can get back to menu when I am playing a track.
Playing disk authored with Ulead MF2, pressing "MENU" on remote brings back the menu on disk.
When playing a disk authored with TMPGEnc DVD, nothing happens when I do that.
Ejecting and reentering disc is the only way I can get to the menu. There must be another way.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 16:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43
