I just got a Cyberhome 1500 recorder and have a question regarding NTSC and PAL.
I know that if my source is NTSC, the recording will be NTSC. If the source is PAL, will the recording be NTSC or PAL? Can I feed a PAL source and have the resulting DVD be NTSC or vice-versa?
Results 1 to 15 of 15
The answer to your question is no. If the source is PAL the output is PAL, if the source if NTSC the output is NTSC. Also you cannot mix PAL and NTSC on a disc. If you record PAL you can only add PAL content to the disc and vice versa.[/quote]
Not sure but this is how it usualy works (tested with Philips DVDR 75/17).
If source is PAL, recording will be PAL. If source is NTSC, recording will be NSTC. No conversion. NTSC and PAL can not be mixed on one DVD.
Can you test it on Cyberhome ? That would be best way to find out.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Thanks. That's exactly what I thought, but I was just too lazy to test it.Originally Posted by Mediaman2000
I was asking because I was going to transfer some PAL videotapes to DVD for my brother, but his player won't play PAL DVDs. He wanted to know if I could do them as NTSC for him. -
I'm going to transfer one of my PAL tapes later, so I'll know for certain then.Originally Posted by donpedro
I am waitingOriginally Posted by LWinchester
I am interested in this since I am trying to keep this type of problems together here:
NTSC (US) recorders that can burn or play PAL - multisystemPinnacle Studio 8 and DV home video editing (ver.9 already home) -
I just did a test which confirmed what was posted earlier. The resulting DVD will be in whatever standard that the source video was. If the source was NTSC, the resulting DVD will be NTSC. If the source was PAL, the resulting DVD will be PAL.Originally Posted by donpedro
One more question here. Does this recorder convert when you play ? Even better question. Can you watch PAL DVD on NTSC TV with this recorder ?
I believe that you can select TV output format. Right ?Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Yes, the recorder will convert when you play, so you can watch PAL DVDs on NTSC TV. (Been there, done that.)Originally Posted by donpedro
Yes.I believe that you can select TV output format. Right ? -
Does it by any chance have PAL tuner too ?
What about somewhere in menu ??? Thank you for your help
I would have try one by myself but local Walmart doesn't have any
The tuner is setup for NTSC with individual channels, rather than PAL based tuners. It may work for PAL signals though? I'll find out in 4 months when I return back to the UK.
Sound good. Just don't forget. I might go back to Europe in 9 months
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
