How long does it take you to encode a SVCD with TMPG or Flask or a VCD? Please tell me your hardware you use
it takes me about 4:30 hours to encode vcd and 6:00 hrs to encode svcd with TMPGenc
i run on a P3 1.0 Ghz -
It takes me 150min (2hr 30min) to encode a movie
I run a PII 400mzg and 128 ram I have LSX encoder (FAST)
i suggest u get TMPGenc becuse it gives lots of tools and options and gives great quality video
Speed depends not only on the hardware, at least, if you create a SVCD. 2passVBR encoding takes double as long as CBR encoding. Every use of filters slows the process down as well. Different frameserve methods end with different speed.
I can encode a 1 hour avi to CBR MPEG in 45 minutes with CCE. But if it is a really shitty avi, that I have to resize, reduce noise, sharpen and such stuff and I do a 3-5pass encoding, it can take 24 hours. -
Takes me (for example) today, while I was away at work.
Took whole project 5hrs, 51min. Note, I mised the 1st
3min. of it for capturing, but I did tape ALL to S-VHS, also,
this project encludes several commercials for clips I wanted
for another project I had in mind.
MY SETUP:
* Athlon 900mhz w/ PC133 128mb ram
* DC10+ to capture (including commercials +/- 10gigs per hour)
* Virtualdub as Frameserver (3 filters)
* TMPGenc as the encoder (my own mod. Template)
* Nero > SVCD <
*** looks greate on my Apex AD-500 and AD-1500 dvd player ***
NOTE, these values (hours) can change, pending on your bitrate(s).
Here's my project specs from TMPGenc's Batch output stats:
ST-Voyager - "Collective" captured from SAT dish
D:\ST-Voy\01.vdr
Started: 10/12/01 8:59:17 AM
Ended: 10/12/01 2:50:01 PM
((Total time: 5:50:44))
D:\ST-Voy\101101-0101-01.mpg
Format: MPEG-2 480x480 29.97fps CQ_VBR quality 65
Input audio file: D:\ST-Voy\01.vdr
Status: Normal completion
(( Processing time: 0:04:26))
D:\ST-Voy\101101-0101-02.mpg
(( Processing time: 1:04:36))
D:\ST-Voy\101101-0101-03.mpg
(( Processing time: 0:59:29))
D:\ST-Voy\101101-0101-04.mpg
(( Processing time: 0:04:14))
D:\ST-Voy\101101-0101-05.mpg
(( Processing time: 0:02:04))
D:\ST-Voy\101101-0101-06.mpg
(( Processing time: 1:07:59))
D:\ST-Voy\101101-0101-07.mpg
(( Processing time: 0:01:50))
D:\ST-Voy\101101-0101-08.mpg
(( Processing time: 0:04:01))
D:\ST-Voy\101101-0101-09.mpg
(( Processing time: 0:56:5
D:\ST-Voy\101101-0101-10.mpg
(( Processing time: 0:04:10))
D:\ST-Voy\101101-0101-11.mpg
(( Processing time: 0:01:32))
D:\ST-Voy\101101-0101-12.mpg
(( Processing time: 1:13:11))
D:\ST-Voy\101101-0101-14.mpg
(( Processing time: 0:06:09))
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 13:05 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 09:14 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Auto encode AVI's and DVD TS_FOLDER's to 10min long FLV files
By patrean in forum Video ConversionReplies: 0Last Post: 6th Jul 2007, 11:36
