I am (learning to) capturing from old Svhs tape made with a Panasonic AG450. There is a lot of wind noise and background noise I would like to remove.
Using Virtual Dub to capture to AVI uncompressed.
Are there filters to remove noise in the audio for Virtual Dub?
Shold this be done during capture?
I am still modifying my hardware so my setup is not finished.
You'll probably want to split the audio out after capture, edit it, then re-combine it with the video stream.
VirtualDub can do that splitting and re-combining, but you'll want an audio editor to clean up the sound.
There are several in the tools section, including:
Audacity - freeware, good but perhaps a little limited
GoldWave - shareware, very good tool
SoundForge - expensive, but the pro tool for audio editing.
There are many others - but those are among the most popular.
All will be able to do some filtering, EQ'ing etc.. to try and clean up your audio.
cheers,
mcdruid. -
Thanks.
One more baby step towards getting to finished product. It will be summer before I get to burning the DVD. :l -
By-the-way, you may want to look into using HuffyUV (which is a lossless codec) rather than capturing uncompressed avi.
HuffyUV doesn't compress all that much - nowhere near most MPEG codecs for example - but it does make the files 2 to 3 times smaller than uncompressed avi - with no quality loss.
The low compression ratio also means it's not very demanding on the system - so you're unlikely to drop frames because of it, even on a fairly low spec machine.
cheers,
mcdruid.
Would like to remove or at least reduce wind sound from M2TS video
By kmw in forum AudioReplies: 5Last Post: 11th Nov 2010, 19:06 -
Cutting out the wind noise from microphone mounted on car roof
By 872156 in forum AudioReplies: 6Last Post: 14th Jun 2009, 20:50 -
removing wind noise
By Reggie6966 in forum AudioReplies: 2Last Post: 31st Aug 2008, 11:47 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 09:10 -
Simple tool for Noise Reduction, Wind, Waves, etc
By Etherel15 in forum RestorationReplies: 1Last Post: 8th Jun 2007, 02:09
