Anybody that uses this software for printing your disc will know that unless you are really lucky you cant print a complete full face disc because the inner diameter settings only go down to 20mm. Some people have been lucky and been able to get it down to 15 using the 1.10E upgrade. But I got it, and no luck. still at 20mm.
On a full face disc you need it down to 15mm to cover the entire area.
Heres a little trick I found while messing with the registry in xp pro.
If the registry scares you then dont mess with this. One wrong move and you can mess up your whole system. But if you do exactly what I say you will be fine.
Go To run, and type in REGEDIT.
This will bring up the registry.
Now find this Key:
HKEY_CURRENT_USER\Software\CORPUS\EPSON Print CD\Printings
Now find the REGDWORD "bore"
Right click on bore and hit modify binary data.
In the small window that appears click on the small dot that indicates decimal values. now change the value to 15.
Hit OK.
The data on the DWORD should look like 0x0000000f (15)
Exit out of regedit if it ask to save changes hit yes.
Now open printcd and you will see it is set to a 15MM center. Sometimes it will stay but if you change the inner diameter above 20 it will go back to the default of 20. Just do it again when you need it. Prints Perfect full face covers.
I am working on printcd in a hexeditor now. So If I find the default setting for the inner diameter I will post how to change it to 15.
Hope this helps somebody.
You guys have helped me enough over the past.
Epson Print CD software - where to download from.......
By Harvy2001 in forum MediaReplies: 77Last Post: 6th Jul 2011, 16:03 -
Epson Print CD - Default Setting
By Marv in forum MediaReplies: 3Last Post: 3rd Jan 2011, 22:27 -
Epson Print CD Program - going from MAC to PC
By Andii in forum MediaReplies: 7Last Post: 14th Aug 2010, 17:26 -
Epson R380 Print Settings
By festeris101 in forum MediaReplies: 5Last Post: 20th Jul 2009, 11:41 -
Epson R 300 Printer - Print CD Software
By karlosfandango in forum ComputerReplies: 5Last Post: 29th Nov 2007, 12:12
