Results 1 to 9 of 9
    Feb 2001
    Rhode Island, USA
    My new mouse came today and I tried it out in some counter-strike and normal windows apps. I also tested it from all distances within my room, and even different rooms of the house, and the mouse works great! Highly recommended mouse for you folks.
    irc.webmaster.com port 6667 #DDR
    Feb 2001
    51`N 5'W #linux & #vcdhelp @ DALnet
    Ive got an Intellimouse Explorer - the one WITH a wire attached to it . It is the best mouse that I have ever used; goes over anything and it doesnt need cleaning. After reading your post... I want the wireless.
    Bet you havent got a remote control for your computer!
    USA
    Wireless mouse ? Why ? When a PC user would be sitting in front of his monitor and not at a distant.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Feb 2001
    Why?
    -_BUMP_-
    Because my mouse wire gets tangled up. Anyway, if there was no market then there would be no product.
    You can control your computer from distance, say for example when you are watching a VCD or something.
    USA
    Treat your mouse like a Yo-Yo and the wire gets tangle up
    On 2001-10-13 14:49:37, d4n13l wrote:
    Why?
    -_BUMP_-
    Feb 2001
    Who gives a "rats" ass? Its only a mouse.
    USA
    The Pussycats do give a "rats" ass.
  8. i was thinking about getting one of these because i hate when my mouse wire gets stuck on stuff when i am playing games but how long do the batteries last?
  9. If your going to go wireless might as well go with an optical wireless mouse. They work great. The batts last about 2 or 3 months depending on how much you use your computer (or so i've been told). I just use a old fashion corded optical mouse.
