  1. is there ny other burning program besides nero that can overburn VCDs? becuase nero 5.0 cannot overburn i dont know y and nero 5.5 is weird and does not display the correct minutes so is there any other burning program?
  2. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    First things first, have you setup NERO's overburning options in the preference window if not do that.
    Goto FILE/PREFERENCES/ and in the first window UNCHECK the check for correct cd before burning, the enter a value of 85.00.0 in the RED MARKER window near the bottom but do not hit apply just yet.
    Next click on the EXPERT FEATURES TAB at the top, CHECK the ENABLE overburn disc at once recording and in the MAXIMUM CD LENGHT, put something like 99.00.0 this is to cater for the 99minute cdr's if your burner supports them, if not don't worry, if you only entend to burn onto 80minute cdr's this will still work, now hit the apply button.
    Now if that don't work, grab yourself VCDImager from the tools section to the left and used that to overburn. IT sholud work no problem because it use's CDRDAO or CDRWIN which are the best overburning software there is.
    Hope that Helps
    _________________
    <font size=-1>[ This Message was edited by: marvel2020 on 2001-10-12 18:16:28 ]</font>
  3. It did not work how can vcdimager overburn it just makes the file an image then it wont let me overburn it by the way i am using ner0 5.0 cuz 5.5 is screwy when it comes to vcdburning
  4. You should never use Nero to burn a CUE/BIN image of a VCD made with VCDImager (or any other proggy). Nero does not correctly burn CUE/BIN images. Read here: http://www.hvrlab.org./~hvr/vcdimager/nero_bug.html for exactly what Nero does incorrectly.
    You should use CDRWin or CDRDAO or Fireburner to burn a CUE/BIN image. These proggies have no problems overburning as long as your media and driver supports it.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. Try NERO 5.535 its the only NERO version I have found that overburns without any bugs.
