I followed this guide:
https://www.videohelp.com/forum/userguides/111846.php
WHen it says File Append-> AVI Segment and I go to append it does not actually add on. The first of two parts is 55 minutes and when i add on it does not append the second part. It is an Xvid file if that makes a difference.
Please Help
THANKS
Does the two files have exactly the same properties? Video codec, bit rate, frame size, audio encoding, bit rate, Hz... It all has to match, or else VDub can't append clips.
Did you also notice the line "You will not be able to join a AVI that uses VBR for audio directly."?
VBR audio is pretty common...
/Mats
Appending audio/video data to an MKV file
By urymf in forum EditingReplies: 5Last Post: 6th Oct 2011, 09:35 -
Problems with Appending AVIs
By wmseith in forum Newbie / General discussionsReplies: 1Last Post: 22nd Sep 2010, 13:15 -
Appending Videos
By dkern in forum Newbie / General discussionsReplies: 0Last Post: 6th May 2010, 14:36 -
Appending .srt in .sub
By kyrcy in forum SubtitleReplies: 1Last Post: 19th Dec 2009, 03:46 -
appending avi segments w/virtualdubmod
By burgkev in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2007, 13:14
