Sup Man, I was wondering is there any program out there that will detect if a DVD movie backup is messed up? In other words, if the program would check the DVD frames throughout the whole movie & tell you if theres a error during the movie or what not. Thanks alot if anyone could help me out.
what kind of error ?
yes - there is hardware and software to check a whole disk ... but for different things ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Well some DVD's I burned have errors on them, meaning the DVD skips during playback but the thing is I dont know which ones messed up or not. I dont wanna have to check each one buy watching them ya know. So I was just wondering if theres a program out there that checks the DVD for errors or anything. Thanx for the feedback
Yeah man, always near the end. Majority of them shits are at the end & yeah Im using the silver top's which are shitty quality I heard. Is it the media? Thanx man I appreciate the feedback
Well you need to run one of the programs that checks who the actual media manufactuer is if you don't know BUT I'd be willing to put money on it being the media causing the problem if the problem is always at the end. Ritek is popular for a reason, because most things that are cheaper suck.
How to edit and make up a prog off a DB disc Q?
By Murray in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2012, 02:42 -
what cuesheet prog do u use
By mikeo1313 in forum AudioReplies: 2Last Post: 18th May 2010, 23:03 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 03:19 -
Which prog to get audio to work on DVD?
By bytheway in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2008, 19:40 -
What prog. encodes several videos without burning?
By Shapeup1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 18:16
