  1. Hi, all.
    Thanks for a great forum, BTW!
    I'm looking for VCDTools X (for running on Jaguar). All links I've found tonight are dead dead dead. I can't even Google it up! Has this project disappeared for a reason, or am I just a dodo?
    Also, sorry to piggyback this, but is there a way to burn using Missing Media Burner to my Pioneer A05 (NOT a SuperDrive, it's an addon, internal in my dual G4-450 Gigabit)? I keep getting errors, which probably means I don't have the right driver selected (generic mmc?), but can't find more info.
    Thanks,
    Dan
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    not sure why the links are down, but ill host one for a bit
    Click here
    you should be able to use that drive, does it show up in the drives option?
    I have two drives like you, you can see they are both represented in the drive tab. i use the drivers as shown
  3. I tried changing the driver to -mmc-raw, and my drive does indeed show up, and the program looks to be making the conversion (SVCD-prepped MPEG file dropped into MMB set to Burn MPEGs To SVCD), but then I get this:
    IODVDServices/1: PIONEER DVD-RW  DVR-105        Rev: 1.21
    Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
    Starting write resid: 68
    at speed 4...
    Pausing 10 seconds - hit CTRL-C to abort.
    Process can be aborted with QUIT signal (usually CTRL-\).
    resid: 104
    Turning BURN-Proof on
    Using 16 byte P-Q sub-channel data mode.
    Executing power calibration...
    Power calibration successful.
    WARNING: No super user permission to setup real time scheduling.
    Writing lead-in and gap...
    ?: Undefined error: 0.  : scsi sendcmd: no error
    CDB:  2A 00 FF FF D6 5B 00 00 0D 00
    status: 0x2 (CHECK CONDITION)
    Sense Bytes: 70 00 02 00 00 00 00 0E 00 00 00 00 04 08 00 00 00 00
    Sense Key: 0x2 Not Ready, Segment 0
    Sense Code: 0x04 Qual 0x08 (logical unit not ready, long write in progress) Fru 0x0
    Sense flags: Blk 0 (not valid)
    resid: 30784
    cmd finished after 0.006s timeout 20s
    ERROR: Write data failed.
    ERROR: Writing failed.
    ... and that's all she wrote. Weird. I'll have to try some other burns tomorrow...
    Thanks for the quick response!!!
    Dan
    EDIT: I also tried setting the "Use Superuser" option and used my password, no difference.
  4. Member galactica's Avatar
    Jan 2003
    hmmmm
    may i suggest passing this along to ross?
    his email is on his site for MMB.
    he is usually quick to reply.
