I know that lots of people have had this problem when making dvds that the audio goes out of sync after around 40 mins of playback on a stand alone dvd player............coz i know that i have !!!.
I'm a lazy bloke that just wants an all in one program to encode author burn avi's onto dvd..............simple eh ?......yea right.
I've tried arcsoft showbiz,nero6 vision express and dvdmovie factory 2 and all do the same thing audio goes out of sync.dvdmovie factoy 2 is the only program that will not transcode a file after encoding.
I emailed both arcsoft and nero to ask why this happends to get only one responce from nero saying *this is funny*..."sorry but we do not have a solution at this time"sounds to me that all they want is your money for the program *that dont work* but when you have a problem they fob you off with that classic line !!.
anyways ive looked for all in one guides on here not to find one that works or if it does it sounds way to complicated to even try.ive heard using tmpgenc is probably the best encoder around......so i used it to get a file about 2gigs big put onto disc to find that the film *original length 1hour 30 mins* is now 4hous 50 mins in length the video is fine but no sound.used tmpgenc again with a different file *slightly smaller one* to get a file too big to put onto dics.....beleive me ive thought about getting a gun and blowing my brains out coz of about 20 hours of wasted time encoding ect.
all i want is a not too confusing guide to put avi. onto dvd from start to finish that works !!!
well heres wishing
Originally Posted by scooby2b2
Avi's come in so many different shapes and sizes that there is no simple solution that works for all. Avi is basically a wrapper format and can contain video and audio in many different compression schemes from uncompressed to mpeg-4 codecs such as divx. Also the audio can be in many different forms from Ac3 to uncompressed wav. So no single solution is available that I know of.
I suggest you pick one of the guides on this site and work thorugh it. When you run into problems come back here and ask specific questions, detailing what you have done so far, and someone may be able to help. -
/Mats
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14 -
ffmpeg avi to mpeg2 quality compared to other progs
By bagrol1 in forum Video ConversionReplies: 3Last Post: 19th Jul 2008, 08:09
