Whats up yall, Im new to the phorum & I was wondering if anyone could help me. I burned a couple of movies using DVD X Copy Xpress. The movies work fine but how would I go about burning a backup of the backup that I just finished burning using Xpress? I tried some progs but the DVD's seem to skip when I view them after. Is it the media? I heard the media is a big factor... I just want to make sure its not the way Im burning the back up. Goodlookin out for the help
Thanx for the reply man, I used Nero before but it seems like I had the same problem, the dvd's were skipping. Just wondering when you copy the original DVD using DVD XCopy, do you leave the shit alone? Or do you multi task? cuz I think I was multi tasking as well & it might have caused the DVD's to skip when burning them using the prog. Let me know, thanx alot man
Layta! -
i leave it alone...put the dvd in hit copy thats all, start messing with settings and could find yourself pulling hair if your not sure what your doing.
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
