  1. i downloaded besweet and when i opened it up i dragged the file in and went thru to step 5, when i select go it says do you want to create a log file,check yes and notepad pops up????? so i found the box that says uncheck log file.....so then i hit go and nothing happens......what the version of besweet i need to re-encode a wav file to ac3?
    Nov 2003
    Wish_I_Was_In_Highbury
    Usually when this happens, the transcoding is failing. If you read the log in the notepad, it will probably tell you what has happened.
    I use the latest version 1.5b23 and have been able to convert .WAV to .AC3 format with varied success. Just make sure you have a FULL version -- with all the necessary DLL's. The log file will tell you if you're missing some.
    You may have to install an older version, then add the new files.
  3. Yes, there's a known problem with lots of different dll's required, and if you miss some, BeSweet will error out.
    Personally, I use the AC3MACHINE front end GUI for BeSweet. I've got it set up so that all I have to rename my WAV file and press GIVE ME AC-3 and it works automatically. AC3MACHINE is highly recommeded (available from www.doom9.org or from a link on the tools section at this site.)
    Be sure to get the ac3enc dll
    https://www.videohelp.com/forum/userguides/129419.php
    Or use my ffmpeggui to convert to ac3 audio (also based on the ffmpeg ac3 encoder that besweeet/ac3machine uses).
  5. Member daamon's Avatar
    Melbourne, Oz
    Baldrick,
    I've read (somewhere) that BeSweet doesn't produce 100% ac3 output. Especially when used in some Pioneer stand-alone DVD players. Is this correct?
    If so:
    1. Why use it?
    2. What else is there that is 100% reliable?
    Cheers.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  6. BALDRICK-thanks alot man ffmpeggui works great!!!!!!!!!
