I need some help with this. I used to have os 9 but I had to do a system recovery kinda thing. No I'm back at mac os 8.5 cause I don't have the os 9 disc anymore. anyway I got my internet connection established but when I try to surf the net with IE or netscape it won't do anything and says something about dns error. Like I can connect to the net but the browser won't do anything like go to any sites or anything, how do I fix this? thanks
Depends, are you dial up, cable modem or DSL? If DSL make sure any special software they gave you is installed AND compatible with an OS that old.
I use dial up. I can connect at 44 100 kbps but when I try to use IE or netscape it wont bring up any websites. thanks
this is pulling from YEARS ago, but you have to make sure tcp/ip is set to your PPP or dial out inorder to get an active IP
its one thing to dial out and connect, its another thing to connect and get a IP
make sure your TCP/IP control pannel is set properly and that you have a ip that refelcts your provider
169.xxx.xxx.xxx implies you dont have a proper connection as its self assigned
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13
