I'm using Avisynth to do some work on old movies that I'm converting to VCD and some of them have those lines in them. Not sure if you'd call it noise or snow. I'm already using the Peach smoother and was wondering if there is anything else I can do to improve the image quality. Thanks.
You might try convolution 3d but it is really impossible to tell you how to filter your video without seeing a frame of the noise. Also I am not good with avisynth so I can not answer you. What you need to do is post some screenshots so you can get links to them. Then go to doom9.org's avisynth forum and post the links to the bad frames and the people there can tell you what filters would work best.
cleaning dvd's
By the_shyguy in forum MediaReplies: 25Last Post: 7th Dec 2009, 05:39 -
Cleaning a DVD??????? Best way???
By vbond0071 in forum Newbie / General discussionsReplies: 19Last Post: 24th Mar 2009, 19:33 -
Cleaning the lens?
By Digiface in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Sep 2008, 11:27 -
Cleaning up old home movies on mpeg
By illyad in forum RestorationReplies: 8Last Post: 10th Dec 2007, 07:01 -
Cleaning the screen
By BroomQueen in forum DVB / IPTVReplies: 1Last Post: 16th Oct 2007, 07:02
