  1. I ripped a DVD using DVDDecrypter in ISO mode to my hard drive.
    It produced 3 files total just under 7Gigs.
    I no longer have a copy of the original DVD, so how can I shrink
    the ISO and get it burned onto one DVDR or even 2 DVDR's if it's not possible to compress it?
    Thanks in advance.
    Noel
    Oct 2003
    Central Texas, USA
    Tiz illegal to copy a copyrighted DVD unless u own it. Therefore I'd advise u to practice on DVD's u own and delete that one.
  3. Hi,
    I am aware of that. This is not copyright material. Its home
    movies transfered to dvd from original cine film.
    I could have the original DVD mailed to me but it would be
    easier to work with the files I have if it is possible.
    Noel
    Install daemon tools and open the iso and you will get a new virtual dvd containg the iso.
    Then just choose any dvd9 to one dvdr guide
    https://www.videohelp.com/guides.php?formatconversionselect=DVD9+to+one+DVDR&search=Search+
    Need to extract ISO files to actual files... ISO Buster maybe?
    Then use DVD2one or DVD Shrink on the files.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    No need to extract if you are using daemon tools.
  7. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    What Baldrick said.
    Load the ISO in Daemon Tools, then you can use DVD Decrypter to rip the virtual DVD drive, then check out one of the tutorials on how to shrink it to fit a 4.7 GB disc.
