  1. If using AnyDVD along with DVD Shrink should you still enable Remove Macrovision in DVD Shrink? Does keeping it enabled slow down the process since AnyDVD is removing the protection anyway?
    Actually, this may fall in with any app that removes protection when used with AnyDVD.
    Dec 2002
    Removing or not removing macrovision will save you no time. It's a setting, not a transcoding issue.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
