My Sony VAIO w/ DVD+/-RW just recently started giving my problems when burning DVD-r's usuing TMPEGenc DVD Author. The computer is only 2 months old, but all of a sudden when I go to burn my authored projects they get maybe 1/4 done and then will say completed and eject the disc. The screen doesn't give any errors, just stops burning and the disc doesn't play at all!
The first few months, everything worked fine! TMPGenc was awesome and all the projects I created burned perfectly. I've now wasted 10 or so dvd-r's trying to figure this out! It will occasionally burn OK on a DVD-RW, but then I'll use a DVD-R and it will create this problem! I've even tried restoring my computer's C drive to the original factory setting and re-installing the software hoping somehow a driver got corrupted. But I get the same problems.
Is my DVD+/-RW drive faulty? It plays fine, but the burning is screwing up. I have a warrenty, but am hoping someone can shed some light on what might be happening.
Thanks to all for your great help! (sorry for the long explanation).
-Jeff
you said about using 10 dvd-r's where they all the same... try using different media. try ritek's.
even try to burn on to dvd+r see if there is any difference.
maybe you just bought a bad batch -
I thought maybe it could be a bad batch, but I used a couple on my Panasonic DMR-E20 and it recorded and finalized fine. It will do cd-r's fine, but I will try another dvd copy program and see how it does. I think I tried and it errored. Maybe I'll do a straight copy using the Veritas Record Now and see what happens.
Thanks, guys!
-Jeff -
Well, I've come to the conclusion that it isn't the media, software or the dvd burner. It seems something is kicking in on my computer to disrupt the burning process.
I can start my computer up and go directly to TMPGEnc and burn a dvd-r disc just fine, but when I do a 2nd it this problem arises. I'm going to disable EVERYTHING else now when burning and see if it stops the problem. The funny thing is, for the 1st two months of owning my computer this never happened. I don't think I installed or did anything different. If I did, it doesn't matter because I restored my C drive to factory settings anyway to try and fix it.
Does anyone have any clue what could be disrupting this?
Thanks-
Jeff
HP vs Sony Vaio
By Tom81 in forum ComputerReplies: 13Last Post: 6th Jul 2011, 23:29 -
Problem burning a project on to a DVD from TMPGEnc Author 3
By vhsal in forum Authoring (DVD)Replies: 5Last Post: 21st May 2011, 19:25 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
