My video CDs burned with Nero play OK on my DVD but cannot be imported in my Premiere filmproject nor can be played on my computer.
Who has an explanation.
Are you accessing the vcd correctly? It just wont start unless u have certain settings set, otherwise you have to navigate to the drive in which the vcd is in and open that drive, click on the folder and open the folder called avsq..... there you will see a DAT file, right click that and use OPEN with and select ur media player. WMP works just fine.
Otherwise, if u have power dvd or widvd, just open it and selct the vcd to play. trust me, if it works on ur standalone dvd player, it will play on ur computer as long as you have the proper media player. Also if it is an svcd, u will need powerdvd or any other mpeg2 media player for it to work.
videoCD to dvd
By rubberman in forum Video ConversionReplies: 9Last Post: 31st Jul 2008, 13:59
