I have recently perchased a DVD over the internet (Bad Boys II) - only to realise that it is in NTSC format, but when I ordered it - It said it was PAL.
I cannot return this DVD to get a refund as the returns period has expired. Is there any way I could convert the NTSC DVD into a PAL DVD. I have a DVD-R burner and Nero 6.0. I would be greatly indebted to any help!
Thank you - Paul Cowell
Have you checked to see if you can hack your player to make it region free???
That won't make any difference. If you have a PAL DVD you need a player and a TV that are PAL capable. The region code has nothing to do with that.Have you checked to see if you can hack your player to make it region free???
Demonstratably not true. Both my players will convert PAL to NTSC on the fly and display them on my NTSC TV. Very useful but little used feature for someone in the US. Fortuantely for me I like bad kung-fu movies from Hong Kong!!! (stuff not released in the us until years later, like Iron Monkey or Shaolin Soccer).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You should have specified which part is not true.
That's correct. With some players you don't need a PAL TV.
However that still has nothing to do with the region code. You (or the manufacturer) could make a PAL disk with any region code (or an NTSC disk with any region code). The region code is not directly related to the system type.
interesting security problem, need some input
By deadrats in forum ComputerReplies: 3Last Post: 23rd Nov 2009, 23:58 -
Interesting Connection Problem. LG DVD Recorder to Samsung LCD TV
By kramsey999 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Oct 2008, 02:13 -
An Interesting Problem
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 9th Jun 2008, 20:15 -
interesting VEGAS 8 render problem
By compusic in forum EditingReplies: 3Last Post: 8th Mar 2008, 09:11 -
Interesting problem with new Sony titles
By Nilfennasion in forum Newbie / General discussionsReplies: 8Last Post: 25th Aug 2007, 09:01
