  1. OK Ive got the Band of Brothers on AVI files, they play OK as AVI. using TEMPGen to convert them to DVD format (PAL 48000htz) to use in Ulead DVD Movie factory (Set to make PAL DVDs) and after the 3-4 hours of waiting theres no sound. The picture is brilliant but no sound I have all the Codecs installed and other MPEGs play fine
    Anyone here got any tips on what to use or how to convert them do the sound works ?
    TIA
    pulling my hair out here folks
  2. GSpot says they are XviD with AC3
