i downloaded a few video clips, i ran them in gspot to find what codecs they use 1.MPEG Video Decoder 2. Elecard MPEG2 Demultiplexer.......what i really wann ask is how come when ever i encode an mpeg to get it to a dvd mpg file, it hardly ever works, i mean ot say that when i load it into tmpgenc dvd author it can never pick up the entire movie.
can someone tell me a sure fire way to encode these mpgs properly
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Hi SIRCOOKS,
You're gonna need to provide more info. Not sure what you mean by "it can never pick up the entire movie".
As a start, these links may help if you're using TMPGEnc to encode the mpg's:
http://dvd-hq.info/Compression.html
http://www.lordsmurf.com/convert/tmpgenc/tmpgencplus.htmThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
tell me what u need and ill get back to you asap...aiight man
try converting your mpegs to dvd files using the software CUCSOFTS AVI to DVD. It also does mpeg to dvd files. Find it under the TOOLS section.
Hi SIRCOOKS,
1. What tool are you using to encode to DVD compliant MPEG2?
2. What do you mean by "it can never pick up the entire movie"? What error message are you getting?
3. What are the audio codecs?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Also,
4. Are you clicking "Add File" or "Add DVD Video" in TMPGEnc DVD Author?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Getting two fatal errors when extracting mpgs from vobs
By Antony in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Apr 2012, 01:24 -
Several movs/mpgs to DVD / Quality decreases on best files
By soundchaser in forum MacReplies: 4Last Post: 2nd Nov 2010, 11:04 -
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 23:37 -
Join several mpgs together
By milway in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 21:49 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 14:35
