I am trying to convert DV video from DV camcorder to PC via Firewire, and then eventually to DVD.
Is it better to:
edit the AVI files that are created (before converstion to MPEG)
OR
convert the AVI files to MPEG files and then edit?
Edit the AVI files, then convert to mpeg.
Hi GeoPappas,
I, as a newbie also, have just succeeded in doing exactly what you're looking to do.
So this link (particularly the latter half and bugster's fine-tuning) may be of use:
https://www.videohelp.com/forum/viewtopic.php?t=190482&highlight=
Hope that helps... Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
InFanView How do I edit size and get it to print the edit
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2008, 10:51 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13
