Hi there.
I've ripped several scenes from different movies using Smart Ripper over the last year.
I've just gotten a DVD-Burner and I want to know how to burn the .VOB files onto a DVD, and not as Data mode, but DVD-Video mode.
If anybody has done this before, can you please help me to do it.
Thanks.
Results 1 to 13 of 13
Hi havash,
Don't take this as gospel coz I've only recently started using it, but I believe that TMPGEnc DVD Author (trialware for 30 days I think) would be a place to start.
I think it can take in .VOB files and then you can create your own menu to play them. There are plenty of guides on the left nav bar.
I would say that if this does work, then there may be other DVD authoring tools that do the same too - check out the tools section for others.
Maybe someone can confirm or deny my belief?
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
TMPGEnc DVD Author does indeed read VOB info, BUT It needs to have an IFO associated with the VOB. If you only have the VOB file itself TMPGEnc DVD Author will probably not be able to read it. You will probably need to convert it back to an mpg2 using another program such as VOBSnoopy or VOBEdit. and then Author it.Don't take this as gospel coz I've only recently started using it, but I believe that TMPGEnc DVD Author (trialware for 30 days I think) would be a place to start.
I hope this helps. -
TDA will open VOBs by themselves if you "add file" instead
of "add DVD video" -
SWEET, Thanks for the correction and the info!TDA will open VOBs by themselves if you "add file" instead
Unfortunately TDA recognizes Time Stamps in vob files and will truncate the file at the first time stamp it finds. For exanple I loaded 25 min. vob,but because it contains time stamps it only loaded 2 min-55 secs. of the file. Since most vob files contain time stamps it's value in opening vob files is questionable at best.
There is a timestamp in every Gop header. Must be something else
stopping it. -
If it was one of those "Optional - do you wish to proceed" type of error messages....add away and make it on an RW disc. Won't hurt to try...Originally Posted by havash
no, it wouldn't let me add it.Originally Posted by hech54
Another thing, I tried adding scenes from different movies, it seemd to work, but then for one movie, it said the audio is different.
Anyone know how to fix this?
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44 -
Missing VIDEO_TS.VOB and all VTS_xx_0.VOB
By PietjePuk314 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 18:44
