I have had my movies transferred from 8mm to MiniDV. Some of the film has a vertical blue line in it. It looks like there must have been a scratch in the original film and miniDV wrote it as a blue line. Can I use some sort of filter in MediaStudio Pro to filter out the blue?
You could use the cropping tool in Ulead MediaStudio Pro to remove the blue line if the line is located somewhere near the edge of the frame.
If not, then you could use the rotoscope (VIDEO PAINT) program...
(screenshot #2)
http://www.ulead.com/msp/screen.htm
...in MediaStudio Pro to remove the blue line, but such a task would involve lots of work, I'm afraid.
Jerry Jones
http://www.jonesgroup.net -
Thanks for the tips. I don't think the cropping feature will work. It is a vertical 1/32" wide blue line almost in the center of the frame.
I had considered Paint, but like you said it would be a lot of work. With the backgrounds varying all thru the frames affected this would be tough. I guess I could treat it like the other scratches in the film which are fine black lines. They are not as noticeable. I could Paint the blue lines black?
problem launching Flip4Mac wmv-StudioPro on a MacBook Pro
By extremelyclueless in forum Newbie / General discussionsReplies: 0Last Post: 21st Apr 2010, 04:42 -
Cheapest Blue Ray Media
By mol3000 in forum MediaReplies: 16Last Post: 16th Feb 2010, 19:58 -
New NON-Blue-Ray DVD Player or better off with WDTV Live HD Network Media?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 12:36 -
Media Center and Blue Ray
By beric3236 in forum Media Center PC / MediaCentersReplies: 2Last Post: 15th Apr 2008, 06:02 -
Can anyone recommend a Blue-Ray SATA Drive for my Media PC?
By the_importer in forum Media Center PC / MediaCentersReplies: 36Last Post: 30th Mar 2008, 12:27
