Hi
My old DVD rom drive is about to give up the ghost, so I'm thinking of replacing it with a second DVD writer.
I have a couple of questions -
1. With 2 DVD writers, will I be able to burn the same project on to both drives at the same time?
2. Will I be able to burn different project A on to drive 1 at the same time as burning project B on to drive 2? It would be excellent to be able to do this.![]()
I use either Nero 6 or RecordNowMAx, depending on how I feel at the time.
Any comments would be appreciated.
Cheers
Well, bit the bullet and got a second DVD writer and the multiple burning works. One thing I've noticed though, is that although it says it's doing multiple burning, on my PC it actually burns them one after the other rather than simultaneously. Is this normal?
Cheers -
I have not tried with DVD burners, but I tried using multiple burners (Sony DRU500A and LG 8320) for CD-R with Nero. You have to check the "use multiple burners" in expert mode and you must be burning the same project to both drives. That way, I burned at 16x (my CD-R rating) on both drives at the same time, not consecutively.
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
When are they going to make multiple layer blu-ray burners and players?
By Onceler2 in forum DVD & Blu-ray WritersReplies: 5Last Post: 14th Jul 2008, 11:32 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 22:53 -
External DVD Burners
By offensekilla in forum DVD & Blu-ray WritersReplies: 9Last Post: 12th May 2007, 16:18
