Again, not my system, but my Mac friend.
Using DVDSP 1.x (whatever came right before 1.5) and Final Cut (2.0?)... using the QuickTime 5 MPEG-2 encoder exported from Final Cut...
But he can only get 720x480 resolutions.![]()
Would an upgrade to QuickTime 6 MPEG2 encoder help?
Does anybody here have success with 352x480 on a Mac?
Captures done with Matrox RTmac (DV AVI captures).
Poor results using Cleaner 5, prefer to avoid the Cleaner route.
Any suggestions?
I have used MediaPipe because it can preserve the correct aspect ratio in PAL/NTSC DV-to-352x576/480 encoding. There are instructions and preconfigured MediaPipe templates at:
http://www.sjoki.uta.fi/~shmhav/MediaPipe_and_SVCD.txt
http://www.sjoki.uta.fi/~shmhav/MediaPipe_templates.sit
MPEG2 Works and ffmpegX also have 352x576/480 a.k.a. Half-D1 or CVD options but currently they don't preserve the aspect ratio. MPEG2 Works author is working on the issue, though. -
Where can he find MPEG-2 Works ?
I see Media Pipe at <http://mediapipe.sourceforge.net/MediaPipe/>
I'm a PC user myself, on all ATI cards, so a bit of a fish out of water... just trying to help a good friend...
So is the QuickTime MPEG-2 plugin a "no-go" on 352x480 ability? He's specifically looking for something that acts as a plugin to Final Cut (preferably). He's also dead-set on continuing to use DVDSP, and I don't blame him on not wanting to switch authoring applications, as I believe was being suggested above (converting to Sizzle).Want my help? Ask here! (not via PM!)
MPEG2 Works is at http://www.mpeg2works.2ya.com/ but check also ffmpegX and MediaPipe. For more info see also:
http://www.sjoki.uta.fi/~shmhav/SVCD_on_a_Macintosh.txt
BTW, there is a new MPEG2 encoder in FCP. It may be more flexible than the old so check it out if you are using FCP.
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
Cannot compare lossless with MPEG-2 encodes: Frames aren't lining up!
By Mini-Me in forum Video ConversionReplies: 15Last Post: 5th Dec 2010, 02:08 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 09:16 -
1024x432 MPEG-2 to H264/MPEG4 encodes render as 576x432
By SiRGadaBout in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2008, 06:37
