hey guys, i got a dvd burner and tried it out and wound up with 3 lovely coasters so far. im using nero, and i tried with and without joliet, as dvd-video and as dvd uhf, and as dvd-r and dvd+r, and really nothing works. my pc surpasses the system reqs so no prob there.
heres the issue. i burn it, it verifies, says everythings okay. so i go to play it in my dvd rom and its fine...until it gets to be about halfway done. its able to play all the chapters until it gets near the middle, then it cant play the chapters anymore and tells me to check for scratched on disc. all 3 are like this, and i tried to burn 2 different shows so its not just 1. any1 know wat could be causing this or how to fix it? thanks so much
What brand of media are you using? Often problems like this are caused by using inferior media, or media that is incompatible with your DVD burner.
I had very similar problems recording with Nero 6 and trying to play back with Power DVD XP. I would be able to play a certain amount of a disk before i got an error message along the lines of corrupt/scratched disk. Problem went away when i played the disk using Win DVD.
I've since returned to using Nero 5.5 and now have no problems with play back on PowerDVD or WinDVD
Hope this is of help
Play from latest point
By spliffenheimer in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2010, 12:54 -
DVD Play Back
By rcoran in forum Portable VideoReplies: 1Last Post: 4th Oct 2009, 03:26 -
Pinnacle Studio - Will not render past halfway point
By pooty13901 in forum Authoring (DVD)Replies: 4Last Post: 14th Jun 2008, 21:47 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
DVD+R Doesn't play after halfway through
By cfresh13 in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 20:28
