What can I use to Re-Encode a DVD and keep 1 or more of the original audio tracks? I definately want to keep the 5.1 sound, and maybe a commentary. I want it to look decent, and don't want to use programs like DVDShrink or DVD2One for this because they need to compress 7GB down to 4.7, and they won't turn out too great..
In that case, I would suggest TMPEGenc.
There are a few guides dotted about both here and say doom9.org that tell you how to strip the streams, re-encode the video and re-multiplex the whole lot back together again. -
You can save it with DVD2One. It lets you choose what you want to save or you can save the whole DVD without compression. Then you can use DVD Shrink to split the 7gb DVD into 2 DVd's so you can burn to 2 DVDR's
That is true, but the original post clearly says no to both DVD Shrink and DVD2ONE...
The choppy playback is probably your choice of media. However naff remultiplexing and / or data rates over the spec could also be to blame. -
Almost forgot ( actually I did forget ) use osex. It will let you choose what you want to keep and it wont recompress and then you can use DVD Shrink just to split what you've kept if it's to big to fit on one DVD.
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 10:41 -
Ripping and Keeping HD Audio
By SeeManRun in forum AudioReplies: 0Last Post: 26th May 2008, 23:00 -
re-encode while keeping the exact number of frames
By bt04 in forum Video ConversionReplies: 16Last Post: 25th Feb 2008, 19:21 -
DVD to x264, keeping AC3 audio, chapters, subtitles?
By Valnar in forum Video ConversionReplies: 2Last Post: 29th Dec 2007, 22:45 -
How to edit multi audio dvd s ? (dts, dolby digital keeping both)
By live4fun in forum EditingReplies: 10Last Post: 3rd Jul 2007, 04:08
