  1. Hello
    Is there any software that can compress the MPGs' files to high compression format?
    thank you
  2. Member Innershield's Avatar
    Jul 2001
    Akron, Ohio
    There are lots of software that can do this with lots of different high compression codecs. See the "how to" section on the left side of your screen.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    There are several avi codecs like divx or xvid that will compress better than mpeg. Look in the guides for mpeg to avi.
