I cant change my drive select. When i click on drive select the box is blank. I can play movies on my DVD rom and my burner,but it will not show up in the drive select. Any help would be great.
DVDXCopy (and Xpress) don't care about your DVD ROM. The only drive you can select is a DVD burner. So if you don't have a DVD burner then there's nothing to select.
I got a TDK 440n burner man. It worked for about a week, and before it got screwed up i had the option to read from either drive,but know it will not read from either one and i cant select which drive. Its just blank.
Problem with TMPGEnc Xpress 4
By milindb1 in forum Video ConversionReplies: 1Last Post: 20th Aug 2008, 04:43 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Major Problem with DVD Xpress DX2
By AcidFMHQ in forum Capturing and VCRReplies: 0Last Post: 22nd Aug 2007, 07:02 -
TMPGEnc 3.0 Xpress problem
By adamthered in forum Video ConversionReplies: 2Last Post: 7th Jul 2007, 18:22 -
old copy of dvd xcopy xpress
By wisconsin girl in forum DVD RippingReplies: 2Last Post: 3rd Jun 2007, 18:19
