I'm trying to encode a 1GB 137minute divx file to fit onto one vcd. I used kwag's kvcd templates but that just results in a much larger file. Why won't this work?
make sure you have selected in TMPGEnc
MPEG settings->System->Stream Type the value MPEG-1 Video-CD (non standard)
These templates are based on CQ (Constant Quality) value
You can get this value with another tool like CQMatic
The whole process to find the right value named Prediction
i fit a 130min movie, with the right CQ and template, in 1 CD-R with acceptable quality !!!
You can find a lot of infos here
http://kvcd.net/forum/index.php
and here
http://kvcd.net/forum/viewforum.php?f=27
and here
http://kvcd.net/forum/viewforum.php?f=64
hoped i helped -
Also make sure the divx source file does not have VBR audio, this really confuses TmpGenc. To check open the divx in virtualdub. If a warning about VBR audio appears, that is your problem. In that case use virtualdub to extract the audio to a wav file (uncompressed) and use that as the source audio when you encode.
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 06:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 20:05 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 08:01
