It looks as if you are required to have a thumbnail. Yuck...
I hope I am just not doing something right. All I want is a "Play All" button (this I can do), but I don't want a thumbnail.
Thanks for any info.
-Brian
Results 1 to 9 of 9
I haven't found a way to delete the thumbnail yet, but you could shrink it down in the edit menu and put it outside of the "TV safe area" Then it would not be visible on a normal tv.
To view the "TV safe area" look under options in the menu edit area.
Hope this helps -
Make sure you have the latest version of DVD Author. You have to choose "new theme" under the menu choices. There you will find main menus that only list the title of the track. If you don't want that, you can delete the text and leave only the play all button.
EASY....in the display menu settings ,select chapter display , it will show you all the clips you incerted in your dvd menu.....to get rid of them uncheck the box....boom ...they are gone
I unchecked them all, but that thumbnail on the main page was still there. I couldn't delete it.
Thanks--I will check on that. My version is 1.15 (trial edition). I just downloaded it yesteday.Originally Posted by parallax1
I brought this up to Pegasys Inc. and posted the results on this topic:
https://www.videohelp.com/forum/viewtopic.php?t=191558
I hope this helps. -
Are you trying to have chapter points without a menu? If so, just select 'No-Menu'. Granted the DVD will play automatically, but you will still be able to skipto the next chapter.
Jukka -
No--I just wanted to have a menu without a picture button. I just wanted a simple "Play All."
Someone suggested I move it out of the viewable region, and I think that would probably work, but the inflexibility of the menu just bothered me, so I switched to DVDLab. There have been some growing pains, and also a few bugs to deal with, but I actually like DVDLab quite a bit more.
Thanks for the help everyone!
-Brian
"thumbnail" program for a Mac?
By rotuts in forum MacReplies: 4Last Post: 2nd Oct 2011, 19:36 -
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 08:57 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 04:17 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20 -
TMPGEnc DVD Author 3 DivX "Smart Rendering" Bug?
By ln108 in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2007, 12:27
