i have been getting this message when trying to play a vcd i burned on my sony dvd player. what does this mean? i can supply more detailed info if needed. thanks in advance!
That means that a pointer to video data is invalid. What is your authoring process?
converted an avi to mpg with tmpeg, burned with nero.
only weird things are that the avi was @23 fps (not 23.97 which was what it said it would be) is that normal ? im new to this :\ also the mpg was 720 megs, but nero didnt say anything about the mpg being too big when i burned it. -
Hold on...
I thought that error for Sony DVD players simply meant that it couldn't read the disc (e.g., dirty disc).
If you are using CD-R media in a Sony player, the most likely explanation for this is that your player can't read your type of media...
I suggest that you try to see if an audio CD burnt on the same type of media will play on your player.
To solve a media compatibility problem, your only solution to to try out different brands of CD-R media until you find one that works. CD-RW often works better. Many people have had difficulty with Sony units playing recordable CD media in the past so if you do a search of the forums, you'll get an idea on what media brands may work.
Regards.
Michael Tam
w: Morsels of Evidence
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
