Results 1 to 11 of 11
    Nov 2003
    Sherman Oaks. CA
    How can I back up 12 gig .avi files on DVD?
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    backup onto 3 dvd blanks
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Depending on the compression method in the source avi (DV?) you may be able to compress it into a format like Divx which can be considerably smaller. Virtualdub can do that.
    Nov 2003
    Sherman Oaks. CA
    Can it be uncompressed back into .avi?
    Nov 2003
    Sherman Oaks. CA
    How do you split it up?
    Nov 2003
    Sherman Oaks. CA
    Where do you find Divx in virtualdib? I don't see that as a compression option...
    Nov 2003
    Sherman Oaks. CA
    And one more question - what's better quality 1. mpeg-2 or quicktime? What's bigger?
  8. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Divx is a type of avi compression, if you look under video>compression you should see it. If you don't then you need to install a divx codec, look in the Tools section of this site for a link.
    You load your file in Vdub, video>full processing mode, video>compression>divx>configure, file>save avi.
    Nov 2003
    Sherman Oaks. CA
    Anyone know this?
  10. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Don't know about quicktime, but mpeg1 and 2 are the same at equal bitrate and resolution.
  11. 8) mpeg2 is better .. its a much more standard format...and all th etools out there normally work with mpeg2. have you tried zipping up your file? this will also allow it to be split into 4gb chunks..you will need another 12gbs for the zip file tho...
    The electronic components of the power part adopted a lot of Rubycons.
